friz
Forum Replies Created
Viewing 15 posts - 106 through 120 (of 156 total)
  • Author
    Posts
  • in reply to: To deck or not to deck, that is the question. #727
    friz
    I have the same trailer kit without decking and my camper is bolted to it using hockey pucks as spacers.
    in reply to: Northern Tool 5X8 Aluminium Trailer Mods #705
    friz
    The tongue weight as it sits is 56#. By battery and spare will be mounted under the trailer, behind the axle slightly reducing the empty tongue weight.
    in reply to: 5×8 Trailer Questions #701
    friz
    I just posted some pictures of of my installation on this trailer here.
    http://teardropforum.com/forums/topic/northern-tool-5×8-aluminium-trailer-mods/
    in reply to: clc's fan #697
    friz
    Much Better!
    in reply to: Hockey Pucks #662
    friz
    Good to hear. I won’t be mounting mine for a couple weeks yet.
    in reply to: clc's fan #661
    friz
    I agree, it’s all about what works for you. I’m just glad the CLC is willing to accomodate.
    in reply to: clc's fan #658
    friz
    $22.70 to get it back to them. I guess i will have a little under $50 in the switch. Worth it in my opinion.
    in reply to: clc's fan #655
    friz
    They agreed to replace mine as long as I paid shipping. I felt this was fair. Mine is still untouched in the box.
    in reply to: Done! #603
    friz
    Do you only need to varnish or clear the surfaces that get direct sunlight? I’m not sure i want varnish on the floor of the interior or on the floor of the galley. I would think that varnish would be to soft for these surfaces.
    in reply to: Done! #594
    friz
    Nice job!
    If you don’t mind my asking, How much varnish did you need?
    • This reply was modified 9 years ago by friz.
    in reply to: trailer decision #578
    friz
    I went with a trailer that puts the wheels outside of the trailer width in hopes that I can customize the ride height to get this right. I am using the NT 5×8 aluminum trailer. I may move the axle on top of the springs to get the height down. I’ll keep you all posted.
    in reply to: Done! #561
    friz
    let us know if you find a better fitting fan. I’m in the same boat. I’m tempted to cut the flange off and glue it in the hole with sealant.
    in reply to: Galley Flat fitment problem #554
    friz
    I just shaved enough off until I could get it in. Thickened epoxy filled the gap.
    in reply to: Door fit #548
    friz
    I don’t think i am in any position to give advice. I’m just as perplexed with my ever changing door as everybody else. I’m waiting to see what happens when i get my seals in place. Sounds like I will be in for more surprises.
    in reply to: Door hitting eyebrow #539
    friz
    Good to know, Thanks!
