Forum Replies Created
friz
ParticipantI’m with you Eric. I’m pretty sure that I got them close enough not to leak, but I doubt they will be pretty.
friz
ParticipantProbably a frame with some depth around the entire perimeter of the door would have been the best solution. my trailing edge bottom also has a bow in it that will need to be corrected. I figure, I will throw wood at the issue until i get something that works. I too have the floor stiffeners left over to play with.
friz
ParticipantI was thinking the same thing
friz
ParticipantI have yet to try it with the seal installed. I only did the mod on one side in case I need to go further. I’ll post when I know something.
friz
ParticipantI have been on ebay all week getting the bits and pieces I need for my super simple 12v system. A couple items will be on the slow boat from China, so I’m trying to plan ahead a bit.
friz
ParticipantI am considering leaving them off on mine. My fear is that they will get torn up in use anyway.
friz
ParticipantVery cool! Now you need to do door latches to match.
friz
ParticipantI found the issue with my door ”relaxing”. The door skin has actually warped the stiffener. I went ahead and cut the stiffener and applied a layer of glass to reinforce it. We will see if this works.
friz
ParticipantLet me throw this out there for those that don’t need much electrical. I don’t plan on having anything mounted in my galley wall. I want that entire space for storage. I plan to mount my battery, fuse block, and ground bus to my trailer frame. and have my switch/outlet panel in a pod under my shelf. my wiring will come through the floor in front of the bulkhead at the edge of the floor and be tucked behind the headliner.
friz
ParticipantMy hope for doors without a strap may not be possible. My doors continues to relax over time. The bottom front is now protruding about 3/8th inch. I may try to cut the stiffener at the joint, glue and reinforce with glass. I’ll keep you all posted.
friz
ParticipantI just stuffed mine full of thickened epoxy. I’m pretty sure my fillet was able to accomplish this with out the use of performance enhancing drugs.
friz
ParticipantI made an angle finder with two rulers and a clamp and fastidiously checked the angle of the opening against the doors as I was sanding the stiffener into shape. After I glued and clamped the door, I checked the angle of the rear of the door and found it to be still sprung open a bit. That’s why you see the tape stretched over the bucket to the rear corners. Remarkably, the stiffener seems to be able to hold the shape of the front and rear edges.
friz
ParticipantI also want to mention that I had to get really aggressive in removing material from the door stiffener to match the angle of the door to the opening. My doors had sprung open a bunch.
This reply was modified 9 years, 2 months ago by
friz.
friz
ParticipantI am tempted to cut the flange off, let the bottom rest against the bezel, and glue it in with a fillet of silicone.
friz
ParticipantResizing seemed to help
