Forum Replies Created
friz
ParticipantThe only must have electrical device in my camper is the fan.
friz
ParticipantI’m at 3.5 K on mine.
I brew in the house 0.0K
Shoved model airplane stuff into corner to make room in garage 0.0K
Kit 2.3K, trailer .7K, all other misc BS 1K = 4K
Have slept in it 5 nights saving about .1k per night = -.5K
friz
ParticipantThank you for developing this. I would love to eliminate my “travel plugs” in the future. Keep us posted on how it works out.
friz
ParticipantI had the same issue with the routed door stiffener. I figured mine was one of the first kits and they would have changed it by now. This needs to be a service bulletin.
friz
ParticipantI found the pod with the voltmeter, usb and 12v outlet on ebay. I added a momentary switch for the voltmeter so it would not be on all the time. I also added a PWM controller for dimming my led lights.
friz
Participant5 gallons of water over a 1 sq ft area. No more concentrated weight then a battery, I would assume. My battery is mounted under the trailer so I used it’s weight as the standard for loading the galley.
friz
ParticipantI guess you could plans build and use rigid foam instead of marine ply? You would need to glass everything in the round so I don’t know how much of a savings it would be in the end. Mine only weighs 500 lbs empty.
friz
ParticipantI weathered a thunderstorm in my camper over the weekend. I left the travel seals in the front facing vents and had the rear facing open. I had no water inside. The reason i left the seals in the front facing vents is because the curved surface warps the base and leaves a gap between the baffle and the base without the pressure of the travel seal.
friz
ParticipantI have a couple trips and about 1000 miles on my camper. I would not change a thing about my trailer mods. I think the axle placement is about perfect.
friz
ParticipantI wish I could. I need to figure out which boat I am building next winter.
friz
ParticipantNice!
friz
Participanta little cellofill in the mix with the wood flour will lighten up the color if you need to make the routed lines less obvious.
friz
ParticipantI will be camping in it the next three weekends. Glad to be done.
friz
ParticipantSanding will eclipse all other tasks. I think the time saved from omitting these items is really minimal in the entire scheme of things. This is a fairly forgiving medium. I have a couple places where my saw did not track perfectly and I fixed with thickened epoxy. I have to look for them to find them.
This reply was modified 8 years, 10 months ago by
friz.
friz
ParticipantIf this was my plan, I would move the galley floor up 1/2 to 2/3 the height to the ceiling creating a headache rack to put stuff in. I would extend to footwell opening in the bulkhead up to the floor of the galley floor. and cut an opening in bulkhead to allow access to this space.
