Forum Replies Created
friz
friz
ParticipantI thought about that. I plan to install the headliner kit, and it appears to tuck under the bezel. I’m afraid loosing that spacer may mess up the headliner install. Operating the controls will be possible, just knuckle busters.
This reply was modified 9 years, 2 months ago by
friz.
friz
friz
ParticipantI just finished my fan opening last night and dropped the fan in. More annoying then the height outside is how it recesses the controls above the bezel. I may be in the market for a replacement.
friz
ParticipantNope. I was wrong. Flange is on the outside. Maybe he modified his fan?
friz
ParticipantI would guess that John was able to disassemble his fan and mount it with the flange on the inside. Lower profile but maybe harder to get a good seal against the elements.
friz
ParticipantI plan to modify the mushroom vents by gluing a nut into the base and using a piece of all tread glued to the cap, extending through the nut at the base, to a knob in the interior. This should allow me to fine tune the vents from the inside and keep them from unscrewing entirely on the road.
friz
ParticipantFrom pictures I have seen. I believe those are for lights. I would like to know which ones fit those holes for reference.
This reply was modified 9 years, 3 months ago by
friz.
friz
Participant<p style=”text-align: left;”>I started dropping pictures in this thread again. had some requests to continue posting but I am not including any tips. I don’t want to get involved in discussion.</p>
friz.
friz
ParticipantI do want to add that my decision not to post is not reflective of the kit. The fit of the parts so far is astonishing. I can not imagine trying to build this project from plans when a kit this complete is available. Thanks Mr. Harris for a fantastic kit and a very complete manual.
friz
ParticipantHey guys, I’m not posting on TNTTT anymore. I found myself going backwards in the manual too much in order to explain myself to the experts. I need to be focused forward to finish this project.
Thanks, Friz
friz
ParticipantYea! Thanks for showing a varnished finish. That’s my plan also.
friz
ParticipantI would like to know what others are doing for a mattress also. I plan to get one of those comfort foam mattresses that come in the insanely small package and open it inside the trailer full well knowing that I would have to cut it up to get it out.
friz
ParticipantThanks!
friz
ParticipantI can’t see your picture. Can you give us a link where we can see it?
Thanks, Friz
