Reply To: Door fit
I am probably going to live with it for the time being as my teardrop is otherwise finished and road ready. I did ask John Harris what if anything he would do. I did notice in completion photos posted on this site that other teardrop doors have the exact same two figment problems. For anyone in the earlier stages of construction, I suggest that they glue their door stiffeners in BEFORE they cut their doors out ( accessible by crawling through the open transom. One end is located by copper wire through the cnc drill hole, the other through a hole that you drill yourself with a 1/16″ bit. I wish I had as that would go a long way towards avoiding any spring back that the stiffener glue in problem may contribute to or “bake in”. I hope Mr Harris weighs in, as I believe that the majority of teardrop builders will have some version of this problem.
