January 5, 2018 at 7:45 pm
#1554
Robinson Wire Twister, inherited from my grandfather who built experimental aircraft. This tool is intended for twisting wire between drilled bolt heads to stop safety-critical bolts from unscrewing in harsh vibration environments such as aircraft (https://en.wikipedia.org/wiki/Safety_wire). It also works great for twisting the copper wire stitches as loosely or as tightly as needed.
