Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Headliner › Reply To: Headliner
January 3, 2018 at 8:42 pm
#1545
faithie999
if you decide to forgo the velcro method, I would strongly suggest using 3M spray adhesive “77” (maroon can). I used it. it is tacky enough to hold the headliner in place, but not nearly as strong as contact cement, so you can remove a panel without damaging it if you want to install wiring, etc. IIRC it only took one large can, which I bought at Michael’s with a 40% off coupon.
