July 30, 2017 at 5:59 pm
#1121
I’ve had a little trouble with the knobs from Rockler loosing up as the metal part of the Rockler is aluminum and strips out if the set screw is tightened real hard. I ended up drilling through the knob and 5/16 rod and inserting a 6/32 bolt and lock nut and this solved the problem. This would have been easier if done pre installation.
Bill
