Reply To: Electrical Installation
Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Electrical Installation › Reply To: Electrical Installation
Ace hardware had the lights, a. Bit pricey at $40 for 3 of them. Damn things wire was marked wrong, wire with the “-” was the positive lead. Backwards. As for fitting, I cut two 2″ diameter wood discs from 3/4 plywood and sanded them to fit in the holes, then flush mounted the pucks. Drilled a 1/8″ or so hole in the door sill “ear” for the wire. Aluminum tape holds the wire in place.
Wire splicing technique: strip 1/2″ of wire on each, twist ends, slide on heat shrink, form into “J”, hook two “J”‘s together. Solder splice. I mostly used a 140 watt soldering GUN, worked well although a iron would work two. The gun is nice since it gives you lots of heat fast. Let splice cool, slide heat shrink over it and hit it with a BIC lighter.
