February 3, 2017 at 12:50 pm
#528
tomtnt
i also have problem 2 that you described due to the sealing foam material: the lower forward corner bows out.. but only on 1 door.. other door lines up pretty well… I did not use the strap material on the inside – didn’t like the look and didn’t think it would help with this particular problem.
