Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Pictures of how you heat/cool the teardrop › Reply To: Pictures of how you heat/cool the teardrop
November 16, 2016 at 5:35 pm
#315
I have the mushroom vents and vent fan from CLC. I also installed a 12 volt small fan which is mounted in the cabin on the galley wall . For heat I have a 110v small space heater ($20 type) that will overheat the teardrop in about 3 minutes.
No insulation on the floor . If I need either AC or serious heating and insulation, I have made a serious error in planning ; -)
