Reply To: problem with doors?
Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › problem with doors? › Reply To: problem with doors?
November 11, 2016 at 11:04 pm
#307
I did notice some movement in the doors when they were cutout. So when I was about half way through the cutting out process, the already cut edge would either spring in or out about 1/2″. Am I correct in assuming the strap will correct any misalignment, or will the stiffener “bake in” any angle issue from springback?? I do read and will heed the warning about not CAUSING any angle changes with the stiffener.
