Reply To: Galley Flat fitment problem
Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Galley Flat fitment problem › Reply To: Galley Flat fitment problem
UPDATE: well, this caused a lot of stressful thinking. we just weren’t sure we could get it in without causing alignment issues down the road. Even using a LFH was daunting (little frikin’ hammer). It wasn’t the corners that were the issue, it was the sides where the side members are- along the copper staples. I sharpened up my box plane and set it as low is I could. We eased just a bit off of each side. I had drilled several holes in the stiffeners to hang a net or such in the foot compartment at a later date. We attached some ropes to the stiffeners through those holes and then leveraged the flat into place and BANG! it dropped right in to place. 🙂
