Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Flange Spacer Install Before Hatch cut › Reply To: Flange Spacer Install Before Hatch cut
August 2, 2017 at 10:09 pm
#1141
If you can keep the alignment it will probably be stronger than with clamps. Alternatively, once right side up you could use CA glue to hold it in place and use the router, then break the CA glue bond and glue with epoxy with clamps.
