July 27, 2017 at 6:08 am
#1102
Ken, I mounted the lights in the hole in the top of the door frame and ran the wire out the side to come out just before the side. Then it ran down the corner that the door frame made with the wall to the floor. The wire could be hot glued into place, it’s vary thin and hidden once the insolution is in. Ran it then along the floor and up the back of the bulkhead then behind the galley to my breaker panel. I made a round plug that fit into the hole with an overlapping flange all out of wood that allowed me to have a cavity behind it for extra wire and also to screw the lamp into.
