Reply To: Blank vent solution
July 9, 2017 at 6:53 pm
#1011
After reading all of the issues with the vents I am considering not installing them at all. Instead I was considering installing thru hull ports for deck access (approx 4″ dia) and fix a screen to the inside. The caps could be screwed in and are held snug by a rubber washer when on the road. Has anyone else taken this approach?
I do like the lights and will definitely be installing a pair. Look like a great solution for reading in the evenings!
