Reply To: roundover on the bottom of the TD
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum roundover on the bottom of the TD Reply To: roundover on the bottom of the TD
#869
stevie
I used a router on my TD’s bottom.  It went quickly and without incident. Did same for butt block as well.  No doubt other builders have done the same with similar results.
If you’re contemplating omitting the roundovers, I wouldn’t.  Fiberglass cloth will give disappointing results when attempting to negotiate right angles.  Plus, rounded edges are more aesthetically pleasing.
