Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Mushroom vents › Reply To: Mushroom vents
May 1, 2017 at 11:51 am
#745
This is my plan of action. I plan to use the vents as designed because I want to be able to get air when it is raining. I have to front indicator on the baffles facing up. I plan to cut foam disks about 1 in thick to place under the cap for transport. My hope is that it will seal the opening and press the baffle into the base to seal that as well. Wish me luck.
