Installed eyebrows. Easy, but a lot of sanding to fair in the fiberglass. Building galley, also easy, however the hymnal fails to mention there are a couple of days worth of parts prep before you start actually building. Sanding, rounding off edges, stain (I got a nice dark front but the rest was very light colored wood, so decided to stain so it would match up better). Then epoxy coating, cures flip, epoxy, cure, sand sand sand. The assembly is interesting, easy, but LOTS of cello-fill epoxy glue. I’ll finish it up tomorrow or the next day, there will be some finish sanding.
Oh, galley hatch hinges fitted as well as the doors hung.
Did I mention sanding?
