Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › double checking about dashes before doing the main glassing job › Reply To: double checking about dashes before doing the main glassing job
I would say you did the right thing. You’ll be cutting along those dashes later so any little bit of epoxy that gets through the glass will be removed when you cut through it and then when you sand down the remaining dashes/tabs. I recommend doing the same for the hinge holes if they’re not open yet. It is easier to drill/cut through just the epoxy and glass than to get through the small wood block now epoxied in the hole. I doubt you’ll need the tape on the inside for just applying the glass but it doesn’t hurt if it reduces your worry.
As rovineye said, you will want tape in a few of the later steps when you’re putting fillets in and you might have gaps like with the galley floor.
My general advice with the big glass job (lessons learned the hard way):
- Do it in two steps like the manual suggest for newbies.
- Only put enough epoxy on to make the glass go transparent, don’t float it. You can always fill it later.
- Watch the temperature. It is much easier to do if you can keep the work area cool. If you start to feel the epoxy get warm in your hand, toss it. It isn’t worth the few dollars in savings to try to use epoxy that is already kicking because it will just make a big mess. The quicker you get it out of the cup and spread the more working time you’ll have. Mix small batches (like 4 to 8 oz at a time) and work your way up if you feel comfortable with the working time.
- Use the tool that works best for you. I found a foam roller and squeegee worked well for large flat surfaces. A chip brush was good for dabbing in corners and odd edges.
- Layout and cut the fiberglass to avoid waste and save the scraps. I was pretty cautious with my cutting and I still only had about a foot of extra glass at the end. The scraps work well for areas like the fan hatch (inside and out).
-mike
This reply was modified 8 years, 7 months ago by
mpilone.
