Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › double checking about dashes before doing the main glassing job › Reply To: double checking about dashes before doing the main glassing job
September 28, 2017 at 7:07 pm
#1350
rovineye
Kenn,
You would have had no problem seeing the dashes, but that is irrelevant now. There is no downside to putting blue tape in unless you embed it, which won’t happen in this case. Blue tape to dam up can save a lot of sanding time later, especially with fillets in big gaps.
