Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Anyone using 12v lithium battery? › Reply To: Anyone using 12v lithium battery?
August 22, 2017 at 9:55 pm
#1227
As you are not supposed to discharge lead acid batteries below ~50-75% if you calculate needing a 100AH traditional battery would it not make sense to get a 50AH Lion? This is my plan as I have seen them on sale for $350 with a charger included. If we end up needing more power than that I figure I can easily add a second as a backup.
When I look at the other benefits to me it makes sense.
- ~1/2 the $ or less over the life of the battery compared to Lead Acid
- Zero maintenance
- 1/3 weight and 1/2 the size of lead acid (even less for 50AH)
- 100% discharge safely
- Significantly longer life (some say 10x the 500 charge cycles of lead acid but more like 4x-5x with noticeable AH drop after that)
- If sealed properly no gas expelled.
- LFP is not the same as your cell phone battery that “explodes” with violent flames and seems fairly safe
- There are versions that are drop in replacements for lead acid that can use the same charger etc you already have
