Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Anyone using 12v lithium battery? › Reply To: Anyone using 12v lithium battery?
August 22, 2017 at 1:32 pm
#1225
I’m sorry to see that this happened to someone else. The galley is definitely a week point on this camper. I have my battery mounted under the floor and had my galley loaded with normal camping stuff. A cooler and a 5 gal water jug which weighed much less then my battery and had the weight dispersed over a larger area. I though I was safe. This winter I plan to reinforce that seam with a tape on the inside. I will still load the galley lightly in the future. It is disappointing that the galley floor is so weak. You loose a lot of utility having to load lightly.
