Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Thoughts on mounting window ac on interior bulkhead? › Reply To: Thoughts on mounting window ac on interior bulkhead?
July 20, 2017 at 12:47 pm
#1069
Can’t help you with mounting, but you could add temp control with an ink bird ITC1000 for less than $20. If you don’t want to wire it your self, you could use an ink bird 306 or 308. The AC unit plugs into that outlet, the outlet switches on/off using a temperature probe which you can set.
