Reply To: Glassing the shell and my OK, not perfect results
Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Glassing the shell and my OK, not perfect results › Reply To: Glassing the shell and my OK, not perfect results
Thanks for the feedback. Luckily I only ended up with 2 small air bubbles about an 1/8th inch in diameter on the entire shell so I’m not sure if it is worth trying to fix them. I’ll get some better pictures and email CLC this evening.
Ironically I had an electrician out to the house the other day to get a quote on running a subpanel to the garage so I can put AC in. Right now I’m running on a single circuit which is pushing it for AC, lights, and tools. So the $150 AC might cost me 2K for an electrician but it has been on the punch list for a while.
Thanks for the info about blush. I’ll give the vinegar a try to see if it makes any difference.
-mike
