Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Joint between galley Flat and bulkhead failed when plywood delaminated. Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
#1765
rlheestand
Added one layer of 3 inch fiberglass tape to the galley side of the galley flat/bulkhead joint.  I have painted two layers of fiberglass over the tape and will sand it prior to varnishing to make it a little less visible.
View from the galley
Here is the interior.  I have added two layers of fiberglass tape (one 4 inch wide strip and one 3 inch wide strips).  This should be plenty strong.
view from the cabin
Next, sand, varnish and reinstall the galley.
