Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Joint between galley Flat and bulkhead failed when plywood delaminated. › Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
March 18, 2018 at 3:14 pm
#1723
The bulkhead bowed out during the curing leaving part of galley flat/bulkhead joint exposed. I faired in the gap with putty and covered it with 3 inch fiberglass tape. I’ll do the same when I can access the galley. That should hold it.
No pics. The TD is closed up tight right now
