Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Teardrop Stretch
- This topic has 48 replies, 17 voices, and was last updated 11 months ago by
Peter.
September 10, 2018 at 1:57 am #2113
matukas
ParticipantYou are doing such a nice job with this that I am inspired to try it. I extended the standard model by 20 inches and did a paper model. I am not as good as you are with the model so I will cut wood at small scale and try it. Then I will know if the shapes fit for the full scale model.
September 14, 2018 at 7:41 am #2130stretchMike
ParticipantMatukas, greetings and all the best on this adventure. I am happy to share my experiences and opinions with you. Travelling for 10 days, so currently difficult on phone. If you want to email me we can correspond directly. My email:
barnards
then the @ sign
then telus.net
Mike
October 1, 2018 at 4:14 pm #2166stretchMike
ParticipantI decided to paint the bottom of my trailer with U-Pol Raptor black bedliner paint. The kit comes with a spray gun and the process is quite easy – but very smelly – would not want to do this in an attached garage.
I brought the paint up the sides over my underfloor storage add on. Now for the final flip:
October 3, 2018 at 3:02 pm #2168sleeper
ParticipantI welded up a trailer and used 15 inch tires. This allowed for a popdown storage hatch in the rear and made the galley floor only 38 inches high.
October 7, 2018 at 6:45 pm #2174faithie999
Participant15 inch wheels will be much gentler on the bearings than 12 inch wheels. I did the same thing.
October 8, 2018 at 6:57 pm #2178stretchMike
ParticipantTesting 13″ and 14 ” wheels on my trailer. Adjustable spindle arm angles give me some flexibility. One consideration: 14 ” wheels put me just over width limit requiring extra lights in this jurisdiction.
13″ wheels give me 11″ ground clearance and 39″ counter height even with 8 inch underfloor storage box.
Inside I have added buttress blocks inside my storage compartments. These are filleted and taped on all sides and greatly increase rigidity of my double floor and also support my interior hatch lids:
November 15, 2018 at 6:05 pm #2282stretchMike
ParticipantStretch update here:
To avoid the standard door stretch to keep the doors in shape I gave them a full second skin of overlapping birch plywood instead. Glued it up into a temporary mold.So far has kept the shape perfectly.
Next to the hinges, and also modded them, partly because my doors and hatch are heavier than standard and partly for esthetics. I cut three pieces of ply for each side of each hinge, laminated and then shaped to something of a teardrop shape, like so:
November 15, 2018 at 6:12 pm #2283stretchMike
ParticipantNext on to my tow bar to be inserted through underfloor box and bolted through front wall, floor and axle through matching steel plates:
Had a bike rack receiver welded to my frame so that I can easily add a rack:
I will have two batteries in boxes on the diamond plate, so had it drilled to accommodate that.
February 16, 2019 at 11:43 pm #2423stretchMike
ParticipantContinuing with my build, on to the cabin and galley.
My 2ft stretch allowed for addition of two Arctic Tern 300mm x 500mm opening windows in the cabin together with an interior cabinet.
Thanks to ArtisticAdam for info on headliner material which I followed: auto headliner material with 1/4 inch foam backing over 3/4 closed cell foam. My addition was to button the upper panels.
February 16, 2019 at 11:45 pm #2424stretchMike
Participantand the galley with a Dometic stove/sink combo:
February 18, 2019 at 10:31 am #2427DakotaDirk
ParticipantLooks really Nice.
What brand are your windows? Looks like a nice upgrade.
February 18, 2019 at 12:23 pm #2428stretchMike
ParticipantWindows are Arctic Tern brand. Hinges on top with built in roller blinds and bug screens . Will post photos from exterior shortly as soon as I get it out of garage
March 26, 2019 at 3:30 pm #2461stretchMike
ParticipantBuild update: I have just completed my under-counter cabinets on my stretched teardrop.
The stretch allowed me to add an under-counter Dometic fridge/freezer; drawers and storage under my sink.
March 26, 2019 at 3:33 pm #2462stretchMike
Participantand here:
March 31, 2019 at 6:13 pm #2463CaptainSkully
ParticipantSO much goodness here! Very inspirational. Thanks for sharing. Looking forward to the final product.
