Referenced elsewhere in this forum but worth a dedicated mention and image. A cheap soldering iron and a pliers will allow you to remove copper stitches hassle free once the fillet has cured, so you can fillet with stitches in place! I ran out of the accelerator for the CA glue early in the project this worked a treat as an alternative, especially where there is a bit of tension at the joins.
