Reply To: A/C Dist Panel
#2179
rovineye
No. That comes with a few caveats to come at the end.
Overload/shortcircuit protection. Don’t rely on the protection at the campground source. Get a shore power cable that has current protection built in, along with GFCI. Not expensive nor hard to find. That protects everything in your teardrop.
I sized for 20 amps but you could do 15 amps and save more on the cord. All the wiring and receptacles after the shore connection should be sized at or above the protection at the cord.
The caveats are that if you are needing an inverter to get 120VAC out of your battery, you will need something different. If your total anticipated 120v loads exceed the shore cable protection you need something different.
For me, the biggest downfall of an AC distribution box is the depth into the galley. I had one, never installed it, and sold it, and used a small 12v fuse box.
*Legalese : I am an electrical engineer, but I’m not your electrical engineer :-).  And I’ve been drinking.
