I found a perfect sized hole-saw at Lowe’s. Much careful measuring followed and I’m now ready to mount the mushroom vents.
Then it’s on to sealing the galley with epoxy. I have one coat on so far and I have added fiberglass tape along the joinery at the top of the transom with enough coats to fill the weave. I also added some glass under the galley gutter lip where the latch will hit. That should be plenty strong enough now.
Next up is some sanding and then more epoxy coating in the galley and probably in the interior while I’m at it. I have one quart of varnish which I will apply Monday. Today I ordered two more for the exterior and two for the interior. That should be enough for three coats outside and two inside.
