Reply To: Dan's Build
#2116
Dan
Lots of sanding done. Filled some bubbles I got in the eyebrow fiberglass. Galley hatch drip thingie installed. Gas-spring keeper-uppers installed. I decided to just go with the recommended mounting procedure there.
I’m sooo close to varnish. There are really only a few things left for the exterior: some final fillets and the locking handle on the galley hatch, and installing some mushroom vents in the shell. Then I just need some epoxy layers in the galley and a bit more sanding. The interior is totally unfinished, but with varnish on the exterior I’m hoping to make a maiden voyage in two weeks.
