Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Mushroom Vent Assembly › Reply To: Mushroom Vent Assembly
August 27, 2018 at 9:03 am
#2073
I used the inserts and consider them important. They prevent rainwater intrusion into the teardrop. It is the same concept as a dorade box in boats. The insert prevents water entry from above. Water won’t roll uphill. If you use the CLC method you can’t open your vents in a rainstorm – which is exactly when you want the most ventilation.
