Reply To: Fix to Door sills installed backwards
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Fix to Door sills installed backwards Reply To: Fix to Door sills installed backwards
#2038
Dan
Looks like a good fix. I like the symmetry too!
There’s also a little protrusion at the top of the frame where you line up the mounting block for some hardware. Be thoughtful of alignment up there since you won’t have that protrusion to go by.
