Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Trailer Options – Please Help › Reply To: Trailer Options – Please Help
I also just flipped the axle on a Trailer trailer with the 12″ wheels to the ‘over-spring’ position for our teardrop and now have two concerns on the fenders.
1) The L-bracket for the fender has to be in the highest position for the fender to now clear the tire. Even in this position there is only about 1.5 inches between the underside of the fender and the top surface of the tire (and this is with no teardrop on the trailer.) Is this enough clearance as the springs flex on a bumpy road?
2) With the fenders mounted in this ‘high’ position, they will interfere with the sides of the teardrop. I considered shimming them out a bit, but that requires longer T-Bolts, the ends of which will then come perilously close to interfering with the side of the tire. Another approach would be to cut an arc off the inside edge of the fender so that it clears the teardrop.
For any of you that have flipped the axle on a Trailer trailer with 12″ wheels, how did you handle the issue with the fenders?
Thanks!!
