Reply To: Stained CLC Camper Build Progress
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Stained CLC Camper Build Progress Reply To: Stained CLC Camper Build Progress
#1982
ArtisticAdam
Progress Update (Time Spent To Date ~300 hrs) Galley & Cabinets are finished, minus a few holes to drill for the door latches. This was a huge victory and I couldn’t be happier with the results! Left/Right boxes are interior cabinets while the center is for all the electrical components. The 3 galley counter pieces are removable and sandwiched between these and the original galley top will be the plumbing, wiring and insulation.
Started work on the armrest/nightstands seen on the bottom left corner in my concept image:
The armrests will have speakers, a slot for a cellphone with USB charging, and controls for fans and lights.
Next step is to shave/shape the foam which will then be wrapped with the same headliner fabric and capped with the stained wood piece seen above.
I think I may have used too much foam.
