Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Should I try to remove epoxy from door cut lines prior to fiberglass sheathing › Reply To: Should I try to remove epoxy from door cut lines prior to fiberglass sheathing
June 20, 2018 at 6:51 pm
#1906
I had the same situation and had no problems cutting out the doors.
