Ok, so got another layer of epoxy on… this time with squeegee then roller then tipped with a brush. Just doing the second coat with a squeegee wasn’t the best idea. Don’t do that. I’ve got some imperfections from that technique (mostly on the top and front of the shell) that would take a lot of sanding work to get out. Oh well. Good enough for now. I want to move on…
Ooookay, so much progress this weekend! Got on another coat of epoxy (properly this time) on Friday. Cut out all the things on Saturday. Did some galley stuff on Sunday.
So, the hatch. I’m super pleased with the hatch. I made one mistake by cutting the hole with square corners instead of rounded, but that will be covered up later by the supporting structure. It’s basically a flush-mount like I wanted. I’ll most likely be able to just finish the exterior with a fillet after I get the interior structure built. More to come on that.
I was feeling a little stuck with everything being held up by glassing, but now there are plenty of different things to work on at once: doors, top hatch, galley hatch, galley finishing, interior shelf, interior finishing, etc. Booyah!
