Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Joint between galley Flat and bulkhead failed when plywood delaminated. Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
#1725
caveprod
I have been worrying about this aspect for a few months now, and this is what I intend to do. Fibreglass tap along the seam, maybe along the bottom too, it might not look great, but it should be pretty hidden too.
The marine ply boards are 9 and 18 mills thick respectively will be fiberglassed with matt to the bulkhead and the flat. The aluminium bracket will be screwed with maybe six/eight or more wood screws to the bulkhead and flat, the idea being that the load will be supported by the bulkhead as much as anything. I had thought about putting the lead crystal battery on the frame of the trailer, but then it is pretty inaccessible.
I hope my photo came out…
  • This reply was modified 8 years, 1 month ago by caveprod.
