Reply To: Dan's Build
#1676
Dan
Laid up the galley flat this weekend. Thanks to my dad for routing the stiffeners for me! I then took those and aggressively rounded the cabin-facing end on my little disc sander. They’re just stuck down with wood glue which should be stronger than the wood itself, so that’s fine.
I ended up figuring out how to get the galley flat jammed into place without any trimming. There was even a bit of a gap on the starboard side. This sucked up a lot of thickened epoxy from my fillet, so I came back later and added more after the first batch had mostly hardened. I imagine I’ll have a bit of a mess when I get access to the other side.
As all the new fillets were curing, I finally unpacked the floor panels. So heavy! I should get that put together this week and installed next weekend. Stay tuned!
