Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Galley hatch gas springs starting to fail › Reply To: Galley hatch gas springs starting to fail
(sorry–I didn’t see mike’s reply above before replying–and mike found a much better deal on the springs than I did!)
I encountered this problem earlier in the fall, when we got the first blast of cold weather. thanks to the ideal gas law, we know that the pressure of a fixed volume of gas decreases with temperature.
the gas springs that CLC provides with the TD kit have 20lb of force. I had an email exchange with Dillon at CLC who said their testing on the prototype determined that 2 20lb springs were sufficient.
I bought 2 30lb springs, and started by replacing one of the 20’s with a 30. that provided sufficient opening force in my situation, so I didn’t replace the other one.
I would recommend you try the same thing. IIRC, I bought it from amazon for a reasonable price. they are made by Attwood, and the model number you want is SL34-30-5.
the trick to removing the spring is to find the small plastic c-clip at each end of the arm. they are about 3/8″ wide. use a screwdriver to gently pry the clip outward while pulling the spring gently away from its mounting pin. when you have the clip pried out enough the spring will disconnect.
ken
This reply was modified 8 years, 2 months ago by
faithie999.
faithie999.
