Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Stained CLC Camper Build Progress
- This topic has 21 replies, 9 voices, and was last updated 5 years, 2 months ago by
ArtisticAdam.
January 4, 2019 at 10:52 am #2376
Volund
ParticipantLove the progress- A couple questions if you don’t mind taking the time.
– Now that you’ve had a couple months with the non-factory hinges, are you still happy with them? I love the look of the stainless steel vs the chunky wood kit hinges and would definitely consider going that route if they’re working well for you.
– With your passthroughs from the cabin to the galley, am I right in thinking you reinforced the cutouts with the boxes (they look filleted to the bulkhead?). I’m assuming there would be too much flex in the bulkhead panel with the gas struts and no additional reinforcement with that much material removed?January 4, 2019 at 1:02 pm #2377ArtisticAdam
ParticipantThanks Volund. I would be happy to answer any questions. The stainless steel hinges on the side doors work very well, I highly recommend them. The hinges for the hatch requiring the custom hinge blocks were a bit of a nightmare to engineer, but they work like a charm.
The cutouts on the bulkhead did not seem to weaken the structure but the cabinet units are indeed epoxied in place (both to the bulkhead and galley floor structure). The cabinets, cabin shelf, and galley floor add additional strength to the bulkhead as well. None of the cutouts on the bulkhead went higher up than the gas spring mounting points so I haven’t noticed any flexing. I’ve also upgraded both gas springs to 30lb versions with no problems.
February 11, 2020 at 9:03 pm #2890canadianhoser
ParticipantCan you share where you got your cam locks for the galley hatch?
July 13, 2020 at 1:46 pm #3131Sabonnar
ParticipantHey, thanks for posting such great photos and notes of your build! What did you use for the interior insulation? It looks great.
July 14, 2020 at 10:54 am #3134ArtisticAdam
ParticipantThe interior is 3/4inch closed cell foam covered with foam backed automotive headliner. I used 3M 90 spray adhesive to secure the headliner to the closed cell foam and velcro to secure each panel to the cameper shell. Most of the pieces are held in well with friction but the velcro allows me to remove the panels for cleaning.
November 23, 2020 at 6:25 pm #3289ssnspoon
ParticipantNovember 24, 2020 at 5:46 pm #3290ArtisticAdam
ParticipantCam locks were sourced from Mcmaster Carr i believe. https://www.mcmaster.com/locks/cam-locks-and-latches/keyed-cam-locks-12/
