Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › door lock and trailer lock
- This topic has 27 replies, 20 voices, and was last updated 9 months, 3 weeks ago by
mel.
October 24, 2021 at 12:45 pm #3936
Deepwoods
ParticipantMaster sells a set of three locks, all keyed the same, to address the vulnerabilities in the hitch-to-coupler assembly and keep a thief from driving off with your labor of love. There’s a lock for the receiver hitch, another that fills the area where the hitch ball goes into the coupling, and a third to lock down the latch on the coupler. When the teardrop is detached, I put use this third lock to also secure the chains. I got my set of Master locks from Northern Tool.
December 27, 2021 at 11:30 am #4070Anonymous
InactiveI would recommend Trimark camper door lock. It requires internal and external setup and comes with two sets of master keys, which we were completely satisfied with. It is suitable for residential doors with thicknesses from 1.39″ to 1.6”.
February 13, 2022 at 6:11 pm #4194madebymike60
ParticipantHere’s another door lock idea. I had some old window locks similar to (and maybe exactly like) ‘Defender Security U 9819 Sliding Window Security Lock’ on Amazon but I can’t guarantee they’re the same. Mine fit onto the door rods but were too big for the door to close so I cut the ends of a couple to shorten them. Here’s what I ended up with.
When the set screw is loosened, the rod just slides up and down through the lock. Tightening the screw, with the door closed and handle turned, prevents the rod from being able to slide.
February 13, 2022 at 6:21 pm #4195madebymike60
ParticipantInside, it looks like this. As long as you can tighten the screw enough, it should make it very hard for the door to be opened from outside. I turned the handle until the door was beginning to bend and the lock held but I may flatten the side of the rod for even better grip.
February 15, 2022 at 4:33 pm #4198madebymike60
ParticipantSo here it is with a notch cut which will make it pretty much impossible to lower the rod with the screw tightened at the notch. I used a rotary tool to start it and cleaned it up with a small file.
April 21, 2022 at 11:35 am #4276Anonymous
InactiveI used a deadbolt on my RV and it has been installed by an expert from a locksmith largo company near.
June 1, 2022 at 5:43 am #4330Anonymous
InactiveWhat method should you use to pick a lock from the many options? Consider the Trimark camper door lock. It comes with two master keys and needs to be configured both internally and externally. To blend in with most RVs and campers, it is powder-coated black. The lock should suit 1.39″ to 1.6″ thick residential entry doors. Most travel trailers should be able to fit in this capacity.
June 20, 2022 at 1:15 pm #4351Anonymous
InactiveI would use a locksmith as an option to deal with the trunk door lock problem as they can handle that problem with care.
June 30, 2022 at 7:30 am #4353Gracie Vaughn
ParticipantIn the door sill, directly above the latch, I use a straightforward butterfly screw.
January 24, 2025 at 11:29 am #22138493Anonymous
InactiveConsulting a professional locksmith is an excellent way to enhance your trailer’s security. They can install interior locks, such as deadbolts or latch locks, for added peace of mind at night. To prevent your trailer from being moved at a campground, a locksmith can also recommend and provide hitch locks or wheel locks. These solutions effectively deter unauthorized towing or rolling. Combining interior and exterior security measures ensures optimal protection, letting you rest easy or leave your trailer unattended confidently.
February 6, 2025 at 9:36 pm #22138494Honour
