Coating/Painting TD Underside Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Coating/Painting TD Underside This topic has 5 replies, 6 voices, and was last updated 7 years, 4 months ago by SOMDTD. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts July 27, 2018 at 1:37 pm #1994 Tom B TexasParticipant What has everyone used to coat the underside of the TearDrop? I was considering applying a LineX type coating. I don’t see any reason to put Brightside or other expensive Paint on underside… comments? July 27, 2018 at 5:46 pm #1995 frizParticipant Mine has one coat of varnish. July 27, 2018 at 10:33 pm #1996 marlin53Participant I used a rhino liner type of paint. Hard to keep clean but won’t scratch or peel. July 30, 2018 at 3:48 pm #2000 CWStevensParticipant We used Rust-Oleum Automotive Black Truck Bed Coating in the CLC Teardrop class… http://amazon.com/Rust-Oleum-Automotive-248915-32-Ounce-Coating/dp/B0070S7U4Y Make sure you use the appropriate mask/filter, as you’ll be tasting this stuff for days! August 8, 2018 at 2:59 pm #2016 DanParticipant Three coats of Total Boat topside paint over Total Boat primer. Then a coating of automotive wax. Should be pretty durable. We’ll see. August 8, 2018 at 11:11 pm #2021 SOMDTDParticipant Simple black enamel. The glass and epoxy is pretty tough, don’t overthink this. Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
