Reply To: Should I try to remove epoxy from door cut lines prior to fiberglass sheathing
Welcome to TeardropForum.com Forums Teardrop Builders’ Forum Should I try to remove epoxy from door cut lines prior to fiberglass sheathing Reply To: Should I try to remove epoxy from door cut lines prior to fiberglass sheathing
#1910
Dan
I also had no issues cutting through the epoxy. Most of my lines were filled with epoxy because I backed them with tape before doing the exterior fiberglass job. I didn’t want runs inside.
I had other issues when it came to cutting the rounded door corners. I think the bansai saw I got wasn’t very good…  too few teeth per inch meant the cut was too aggressive and I had a hard time following the curve.
  • This reply was modified 7 years, 10 months ago by Dan.
