Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Joint between galley Flat and bulkhead failed when plywood delaminated. › Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
April 6, 2018 at 6:24 am
#1751
friz–i ordered an AGM battery and will mount it under the camper. could you pls point me to the thread where you have pictures of your mounting arrangement? also, did you find any kind of nifty weathertight fitting for passing the battery wiring through the floor?
thanks
ken
