Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Joint between galley Flat and bulkhead failed when plywood delaminated. › Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
March 14, 2018 at 7:42 pm
#1718
I think the strip of fiberglass tape inside the cabin (the “outside” corner of the failed joint) is more important than the inside corner, at the rear of the galley. but I would do both.
