Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Joint between galley Flat and bulkhead failed when plywood delaminated. › Reply To: Joint between galley Flat and bulkhead failed when plywood delaminated.
March 12, 2018 at 3:46 pm
#1705
Just spoke with CLC and they were very helpful. The recommendation now is to reinforce that joint with a strip of fiberglass during building. They are supplying a 4″ strip which I will use to reinforce the joint from within the cabin.
