Ok, now here’s where I ran into my first issue(s). My epoxy was setting way too quickly for me to do both side seams at the same time. That’s why there are no pics of my not-so-great filleting work. I got my thickened epoxy too runny at first and then over compensated and had to deal with it being too firm. That took some time but I decided to roll with it. I was running out of working time in the thickened epoxy but didn’t realize it until I had laid up both fillets (poorly). At this point I should have scraped both fillets and started over with a fresh batch of properly thickened epoxy and only done one side at a time.
Instead of being smart, I continued on by re-applying a thin brushing of un-thickened epoxy to both fillets and rolled out the correct amount of fiberglass tape on each side. By the time I got to saturating the second side, the tape had stuck well enough that I couldn’t adjust it without tearing out the fillet and I was left with this mess:
Welllll, that’s not good. So I fixed it the best way I could think of without starting over, which I’m not sure I could have done at this point anyway. I just cut the folds and smoothed them down. I won’t have a huge fold to sand down… just a little bump. I’ll just have to live with the tape on that side being a little off-center on the fillet.
I’m very pleased with the center seam. Very displeased with the sides. Overall, glad I get to move on to the next steps. Many lessons have been learned.
