Welcome to TeardropForum.com › Forums › Teardrop Builders’ Forum › Galley Flat fitment problem › Reply To: Galley Flat fitment problem
October 23, 2017 at 6:19 pm
#1414
if the chamfered piece of wood you referred to is made of hardwood, not plywood, it is probably the stiffener that goes on the inside forward edge of the galley hatch, once you cut it loose from the cabin. read ahead in the manual to confirm that is the piece that you are looking at.
